Help me with my 95'' build
Eventually I will be warming the engine up in my 06 heritage with EFI. I would like some opinions and suggestions as I am new to twin cams. It has 14,000 miles. So far my plan is to use SE high compression pistons, thundermax with auto tune, I already have V&H longshots with baffles so I will keep them. Can I get some cam suggestions? I want lots of bottem-mid range power, good passing power, throttle response, etc. I would like to use the stock heads and valve sizes with some mild porting and reworking. Maybe big boy cycles? So all in all I would like to keep the cost down and keep reliability. Any suggestions would be appreciated, thanks.
I have the Andrews TW37Gs in my 2005 FLHRS 95 inch. I have Dewey's street port heads, Forged flat tops with .050 off heads for 10:1 compression. I run a 44mm carb and DTT ignition with 93 oct gas for 100/102 power. Low cost and should run forever. Pulls my wife, our trailer, and myself wherever we head with no effort and 35-45mpg depending on mountains.
Ok so the andrews cams would be better for my application than the wood tw6? What is the best way to do a 95 cylinder/piston kit on a budget? I was thinking of having my cylinders bored by a local machine shop and using keith black, wiseco or even screaming eagle pistons. One more question, chain or gear drive cams? Thanks.
Was only making mention of the 37 as it is a tick less expensive, but the Wood 6 is in fact our choice here.
With our Stage II Heads on that, tuned, it will show 100-105 hp, 110-115 ft/lbs. over a very broad band.
Scott
I have built a few 95 setups using the Andrews 37 cams and BigBoyz heads. They typically run in the mid 90's HP and 105 plus torque with a VERY nice torque curve depending on pipes used. While I run the Wood cams in my own bike I feel the gains if any with this setup over the 37 would not be worth the dollars spent. Dollar for dollar I have yet to see a better more reliable combo than the SE1550 piston, 37cam BigBoyz combo.
Client cam in with a 95"/37 cam/D&D Fatcat(left Saturday).
With our Gen Stage II Heads and his 2 pc Delphi, bored from 41-46.5mm, we dyno "checked" his build which we squeaked 9.8 cr into it, via re-surface.
It showed us 97.1 hp and 102.3 ft/lbs, and is NOW, going to our EFI tuner. www.joescyclerepair.com.
Looking forward to the results, asap.
SCott
SCott
SafetyFifth
Engine Mechanical Topics
31
08-31-2017 05:56 AM
