107", Wood 555, Stage III Heads
Jamie, from Fuel-Moto, just tuned a 107" of our, with our Stage III Heads, Wood 555, OE FBW, and his Jackpot Pro Touring Mufflers.
It ran off at 110.02 hp, and 120.03 ft/lbs.
Peak torque @ 3400, and hp peak was @ 5700.
Makes 100 ft/lbs from 2500 thru 5700.
83.27 F
28.95 in-Hg.
Humdity 6%
SAE 1.02
Client says it picks the tire on the FLHX with roll-on throttle around 3000 rpms.
Sounds like fun to me!!
Scott
83.27 F
28.95 in-Hg.
Humdity 6%
SAE 1.02
Scott
Scott
The 8 requires more compression, and won't hit as hard down low, and will move the power over to the right, and will out-horsepower the little hopped-up 6(555), from what we could say. Have never done back/back, as the 555 just came to market about 6-7 weeks ago, but the cam specs will alert to this.
Scott
Scott
Scott
Scott
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Thanks Scott and Jamie. I appreciate the feedback. I can't stop "tinkering" with anything.....no matter how it runs. My 113" currently has the T-Man 590, set at about 10.6-10.7:1 compression. I need to get it back on the drum and do a side-by-side comparison with the Fatcat Std baffle vs Big Bore Quiet. After that, I may work myself into the cam chest and do more testing. Heads are only set up for .600 lift, so I don't want to pull 'em and change springs.
I fully agree Scott, the TW-555 (which is really a variation of the 6-6) will have very different characteristics than the TW8-6. The TW6-6 and TW-555 are designed as drop in cams. The 8 cam is pretty agressive, it requires different valve springs and for best results more compression. With the right combination it would definetly be a very strong runner.
Thank you,
Not Jamie, but being Bob Wood's largest account, we have worked with that grind many, many times. From 95"ers to 124"(YIKES!!!)
Absolutely brutal torque delivery,(his 408 will carry out further, although) that'll just about flatline, set-up correctly.
Like turning a light switch on.
You'll need roller rocker arms for that one, and a strong grip.
Scott
Scott
