Cam LIft
Talked with you a year ago Scott. Hate I got swayed somewhere else.
So with yer stage II heads I will notise a difference.
ARe you gonna want to move my compression ratio up to 10.25 and I guess yer gonna use compression releases.
excuse my not knowing but what is bored Delphi, is this boring the cylinders ?
A bored Delphi is the 2-pc unit, and was under the assumption that your model was so equipped.
PaulS, makes a very good point in regards to the 1.725 rocker arms.
That would kick things in the a$$ as well.
Scott
How would the 1.725's work just on the intake side of a 96"/SE204/.030 hg/mild head work? I see some just using them on the intake side only. Maybe buy a set and sell the other 1/2. Anyone have 1/2 a set for sale?? Just kinda getting ideas....
HDF Tech
Engine Mechanical Topics
07-06-2005 12:06 PM
