Headwork 95 build
Headwork 95 build
Bike is an 04 roadking fi. 95 se piston(get from online 20% off) bored jugs. Cam choice either se 203/204, Andrews 21,26 or hq 0034. How much are we leaving on the table with using stock heads vs sending them to bean for his $300 job? Trying to keep cost down, but still done right.
Anyone have any reviews on the $500 kompressor heads?
Those compressor heads are a stock 06 head milled .060. Intake flanges adjusted accordingly. Not bad and an improvement over what you have but a little stout on compression for the cams mentioned.
Milling your heads will give you most of what the budget port work does.
If the heads get a concentric 4 angle seat and radius on exhaust same <.001 runout plus new guides you will have helped longevity, seal, and oil control. My recommendation...
Find a set of used 06up TC heads (~$200) and have them properly blueprinted (~$375) and CCs adjusted to the cam you choose. Of the ones you mentioned I would use the 204.
This is budget thrifty and will get you good bang for the buck.
Prodigal_Sun (03-21-2020)
have the heads CCed, and equalized, run a .030 head gasket and do a mild port job keeping the OE valves would give it a good kick in the pants.
as stated above, BigBoyz head service is the value leader here.
Also install a set of S/E 1.725 rocker arms.
This will DRAMATICALLY pull much more power into your set-up, cool it off(especially with that constricted exhaust port) and be very smooth as well.
Another point I'll bring up, is the boring of your 2 pc Delphi t/body from 41 to 46.5mm.
Call us with any questions.
Scott
Not sure what pistons im going to use. Trying to keep cost down. I would like to just do a complet kit with their headwork from HQ or Hillside but not sure its in my budget for them. That way I know everything is ready to go and fits right.
