Loyal AMSOIL users take a look
Old 09-28-2010, 08:04 PM
PakMul's Avatar
PakMul
PakMul is offline
Personally, I'd say it looked like a bearing problem, not an oil problem. Most oiling problems I've seen hve eaten up more of the motor, not just one bearing failure. The rest of that cam looks ok compared to the bearing surface.
I still use 20-50 and change it every 2500.......
Old 09-28-2010, 08:24 PM
Neckball's Avatar
Neckball
Neckball is offline
Between the bearing and the camshaft itself, wouldn't you say the camshaft would be a harder, more durable material? Maybe the problem is the cam ( heat treat?)
Or is that the bearing stuck on the end of the cam?
Old 09-29-2010, 05:38 AM
troop's Avatar
troop
troop is offline
Originally Posted by arealinvestor
5,000 miles between changes is a bit much.But,Amsoil is ok oil.It's not the greatest.Where you using synthetic??
I thought all Amsoil products are synthetic?? I'd think 5k miles on synthetic shouldn't be a problem unless all your rides are so short as to not heat up your oil...
Old 09-29-2010, 05:43 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,167 Likes on 3,676 Posts
You can run 5000 miles on Dino oil...
Old 09-29-2010, 05:51 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Originally Posted by Dalton
If you have changed the oil regularly and not beaten the engine to death, it is highly unlikely that it is an oiling issue.
And yes, you have poked a hornets nest, many are devoutly dedicated to a certain oil and will defend it to death. (I don't use Amsoil by the way)
I agree.
Oil-related threads seem to take on a heart, and lung of their own, and some can become a raging monster.
But the culprit at the root of that cam bearing journal failure, is the inadaquete OE bearing, that contains only half of the rollers, as that of a Torrington, or Sonnax unit.
Scott
Old 09-29-2010, 05:55 AM
Notgrownup's Avatar
Notgrownup
It's a shame that they (MOCO) uses cheap bearings in such a fine machine...I guess it's a roundabout way to get you back in the shop.
Old 09-29-2010, 06:30 AM
arealinvestor's Avatar
arealinvestor
arealinvestor is offline
I didn't think they were.I'm not really a fan of synthetic oil.I change mine out every 2,500 miles.For what they cost,I don't think they are worth it.I had one mechanic tell me he has seen bearing, & lifter problems using synthetic.I think they offer decent protection,but dino is just as good.I wouldn't run any oil in a air cooled motor 5,000 miles.The oil breaks down to quick with the heat generated from these motors,especially with a bad tune, & lean conditions!!!
Old 09-29-2010, 07:42 AM
rob71458's Avatar
rob71458
rob71458 is offline
One of the main advantages of synthetic oil, is that it does not break down like straight oil. That is one of the reasons it costs more, and is far superior. As far as the failed bearing, it has been well known that the OEM style bearing is inferior, and is usualy one of the first things to be changed, when some engine work is being done.
Old 09-29-2010, 09:06 AM
PakMul's Avatar
PakMul
PakMul is offline
Hope it all works out. I hate to see the MoCO use cheap parts in a critical system, but we know it's going on right now.......
Old 09-29-2010, 11:34 AM
Hillsidecycle.com
Sponsor
Whole-heartedly agree with Rob.
Synthetics do protect the engine very well, and it has been proven as to the cooling effects they have, and even increased dyno numbers, but once most thin-up, at full operating temps, lifter pump can be compromised, resulting in unwanted engine noises, from what we have seen.
Scott
Quick Reply: Loyal AMSOIL users take a look
