Blew a header pipe today...suggestions?
03 Anniversary RK Classic:
Riding to work this morning and heard a sudden change in exhaust...sounded like exhaust escaping from under the seat area. Got to work and took a look, with engine running, and it looks like the left header pipe has split at the weld where it turns away from the cyl head...I may be wrong on the exact location of the split since there's a heat shield preventing complete
examination, but it's leaking pretty badly there and I could see either reflection of sparks or sparks coming from the leak.
Not good, but easy enuff to fix. But I'm open to suggestions on whether to pull it and have it welded, replace with OEM style header, replace both headers, or go with a true dual, and with either, which pipe manufacturer? Bubs/V&H/Samson/etc.
open to ideas here...thanks.
Kind of a matter of personal preference, isn't it? Any of those options, with the exception of replacing with a stock piece, are fine. Welding the one thats on there will give you a stronger part. Full Sack performance makes a nice header kit, much cheaper than the competition, and with a nice set of mufflers, your tone and performance would be augmented. And a tuner of course to put in a little more gas. I went that way, with Khrome Werks HP 3.5 mufflers and a Dobeck fuel controller. Good sound, performance, mileage.
It is common to break there. I removed mine and had it welded and it's been fine the past 8 or so years.
Replacements are easy to find at swap meets or from Pals.
I'm a big believer in saving money, the stock configuration header pipes offer good performance results with slip ons.
I always suspected that I contributed to the crack when I man-handled the mufflers during a swap. Like always, try to make sure that clamps evenly support the exhaust system.
True duals offer reduced torque over stock header pipes, it is better to have the 2 cylinders connected by a crossover.
Mike
Mike
That's pretty much what the service mgr at my local shop said yesterday. Those brackets are known for breakage, which eventually leads to breakage of the rear header. We considered all the options (Me and the Parts Mgr and Svc Mgr at Strokers Dallas) and I went with the duals. I figure if I'm gonna change em out may as well eliminate the problem all together and try something different. May end up putting some shark fin mufflers on too.
