Sponsored by: Jekill and Hyde
Cracked block
Old 09-25-2010, 11:43 PM
Tonefiend's Avatar
Tonefiend
Tonefiend is offline
6th Gear
Default Cracked block
I changed my oil the other day. I though I would get some oil out of the case using the drain plug on the bottom. I heard a snap when I broke the bolt free. I thought it was the loctite.
I put put it all back together and all seemed fine, until I noticed a puddle of oil under the bike. I inspected it and found it to be cracked up the side of the case. Here is a picture.
Anyone have any ideas on how to fix this? I do not want to pull the motor if at all possible and would like to find someone who can weld it in place.
Old 09-26-2010, 06:53 AM
street racer's Avatar
street racer
street racer is offline
That the oil pan under the bike,you don't have to pull the engine to remove this part,although its quite a job.I don't think that it could be repaired on the bike.the part will have to be cleaned,welded,and maybe even have to have some machine work done to it.To do it right pull the pan.
Old 09-26-2010, 07:34 AM
moosh's Avatar
moosh
moosh is offline
might try JB weld
http://jbweld.net/index.php
Old 09-26-2010, 09:31 AM
deucer02's Avatar
deucer02
deucer02 is offline
Harley V-Twin is a split case; Left vs. Right. There is no oil pan on these engines.
Old 09-26-2010, 11:23 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
You have to pull the engine. You split one of the engine cases.
Let this be a cautionary tale to others... do not pull plug on engine unless you know what you are doing. That plug is NOT a drain plug. It is a tapered pipe plug
smitty901 (01-01-2021)
Old 09-26-2010, 11:26 AM
wurk_truk's Avatar
wurk_truk
On A engines (dyna and touring)... there is an oil pan, under the transmission! NOT under the engine. The OP ruined the cases of his engine (notice the 'plug' he pulled faced downwards)..
Old 09-26-2010, 11:40 AM
im's Avatar
im
im is offline
Might be less difficult to understand situation knowing year and model of bike.
Many of the plug holes on Harley motors have much more additional threading than is used by the plug itself. Sometimes a longer plug/bolt resolves issues.
How does it look up the plug hole? any threads?
Old 09-26-2010, 11:49 AM
N-gin's Avatar
N-gin
N-gin is offline
Dude that sucks. I think you have to replace the case half if it damaged. I dought someone is going to weld it in place due to the fact it is aluminum and it will damage the surounding aluminum when welded. Once a customer came into the shop with a ford I6. It had a rod knock I have never hear of this in a 4.9 I6 Took the pan off and saw some one welded the leaking pan with it on the engine. Well all the sparks that accured in the pan while he welded left little weld ***** of steel. Well It ruined his oil pump, got into his bearings, imbedded into his cam, mushroomed the lifters, got between the piston skirts cracked some rings, dug into his cylinder walls, even locked one of his lifters. Do your self right and pull it apart you may have more damage then meets to eye. Not to mension some oil passages run though the engine.
Looks to me like you over tightened it.
Its only supose to be snug. Good luck
Old 09-26-2010, 01:24 PM
Tonefiend's Avatar
Tonefiend
6th Gear
Thanks guys. It's an '03 Softail "Fatboy"
First, I hope this is a good lesson for anyone else who does this, and to let everyone know not to mess with that plug. For cripes sakes I pulled thing out with an allen key by hand.
I am going to fix it with JB weld. I have been wanting to build the motor, so maybe in a year or so when the money is there I will pull it out and have it welded when the case is bored.
So the plan is to clean it liberally with brake cleaner, tip the bike over on it's side, grind the crack down, and the surrounding area, and clean it some more. Then I will jb weld the plug, screw it in deep, jb weld the crack and work it in deep. Then loosen the plug back a bit so the crack closes up on the JB Weld, then put some around the head of the crack. I am thinking of laying the bike on it's side to keep the jb weld from sagging.
Old 09-26-2010, 01:57 PM
N-gin's Avatar
N-gin
N-gin is offline
sound like a good plan. I here some good things about JB weld Hope this is another.
Quick Reply: Cracked block
