Hydralic vs. gear driven cams?
I am putting new cams in my 06 Flhrs. While I was doing that, I thought I should replace the chain tensioners. Could someone explain: the benfits of the new hydralic upgrade? (Why is it better than the old shoes, if it still uses shoes) Also, the benfits of gear driven. Of course, the downsides also.
The short story is, I went to the dealer for S&S gear driven 510's. I was talked in to the hydralic upgrade & SE 208 cams...I need to know before it is installed, did I fall for dealer sales pitches, or this set-up is good.
Advantage
The advantage of the hydraulic over the spring load cam chain tensioners is the fact that the spring ones drive on a flat link chain that always slides and hence more wear. However mine are still good at 40 K and after my last inspection expect 100K. The hydraulic uses different sprockets designed for the roller chain that is really the upgrade. Once the side links groove in and the rollers of the chain roll across the shoe the shoes should last life of the motor.
I have done both. I put a set of andrews 37g in my bike and later did a set of 37n's with the conversion plate. I would recommend the hydraulic setup. My gears weren't the noisiest I've ever heard, but the hydraulic setup is super quiet. I don't think the tensioners will wear out any time soon either. the springs put far more tension on the flat chains than the hydraulic setup on the roller chains. With gears, you don't have to worry about tensioner wear, but if your crank/flywheels ever slip, say goodbye to your engine.
