Butterflies over mild build
Old 09-14-2010 | 11:29 PM
mentor70's Avatar
mentor70
Originally Posted by CarbideDude
Guys I dropped the bike off today to have the work done and the service manager is recommending an HSR42 to go along with the other modifications. Will this be a waste of money? Or will it be a noticeable improvement over the stock CV?
i put a Mikuni on my bike, and had it jetted on pretty much a stock motor, and it made almost the same HP and torque as it did with a just Big sucker AC and SE mufflers.
If i had it to do over, id send the stock CV to Woods and have it worked.
Old 09-14-2010 | 11:36 PM
arealinvestor's Avatar
arealinvestor
My 2001 Dyna runs so damn good with just stock 88 jugs, stock heads, stock carb, stock cam, S&S air cleaner, dynajet kit and SE slip-ons. I've been wanting to go to a aftermarket cam mostly to extend engine life by going geared, and also I've been wanting to change to a thunderheader because I just love the way they look and sound. I've already received the cam, which I went with the S&S 510G kit. I know I picked the right cam as I don't plan to get larger jugs or head work and it is highly recommended, but several times in the past I had a great running bike and I just kept fuking around with it till I screwed it up.
Pulling the trigger on a thunderheader tomorrow, and the lifters and adj pushrods. I just hope I don't regret it. Anyone else have this same 510G/thunderheader combo that can reassure me I'm not messing up? If so I'd love to hear it.
Whose installing the gear drive cam?? You should have them your crank's runout before they install the cam!!! i would probably run a +4 advancer with that cam depending on comp your at.If not it might be a little soft on bottom end running stock comp!!! Well, I see you had it done,did they check run out on crank? You might be ok because bike is 01.I think that year has timken bearings!!!
Old 09-15-2010 | 12:26 AM
mplecha's Avatar
mplecha
good cams.. they'd be even better in a 95. Now's the best time to do it.
Manfire
Engine Mechanical Topics
11-20-2017 09:05 AM
JustDennis
02-03-2015 04:15 PM
hell hound
01-13-2011 04:33 PM
dwyleecoyote
47
01-04-2011 04:00 PM
BaggerDave
01-08-2006 08:21 PM
