1982 FXR Gas Tank
RE: 1982 FXR Gas Tank
ORIGINAL: rmarion
Springer
Have you completed any re-coat projects? If so, what product did you use to remove the tank line with?
I just called Red-Kote, they said that the old material must be removed 100% prior to a new application. This might be extremly difficult.
Springer
Good luck and let use know what works.
revising..............
I was talking with my old man.....and asked him about the hp on the FXR. He said depending on the outside temp and some other varibles, it dyno's between 114 & 117 hp...................
I must of been hearing things, oh well, 114 vs 145 it's fairly close........[8D]
I think we found some place to clean and re-coat the tank.
ORIGINAL: rmarion
If you post your Vin number (less the last 6 digits) we can tell you what year your bike is. At this point I don't believe it is a 1982. In 1982 the FXR's had shovelhead engines. The bike in the pictures you posted has an EVOLUTION engine. The EVO didn't come in the FXR (or any bike for that matter) until 1984. It is hard to see some parts of the bike that may identify the year in your pictures. It does have a pre 87 transmission and therefor leads me to believe your bike is between 1984-1986. The front forks seem to be 35mm and that would be consistent with pre 87. It is obviously customized as the rear fender would not have come on an FXR and it looks like it has a retro 3 light dash as well. The tank doesn't appear to be stock either. Other identifying parts would be rear chain or belt? Finned stock rear brake caliper?
It is clearly a branch bike as you pointed out from the paint scheme. It would not surprise me if you could find it in some vintage bike magazine.
30 yr Employee at Branch sounds like John O...........
BTW, John is working on my Oldman ride or within next few day.....Oldman is gonna pump out his Dyna thanks to Branch-O'keefe and Bennett Racing.
Hopefully within next few months my 06 SE Ultra will be giving them a visit...........
ORIGINAL: Spectrexx
Thanks for posting the pics. I've forwarded them, along with Dick Marion's name, to my friend at Branch. That should help jog his memory.....
Oldman says the bike was tested, dyno'ed and wrote up in some old bike rags...I could not find the info after some google searching.
BTW, I'll get the oldman to respond to the thread (he's original owner). Plus I've misinformed a few statements (not on purpose)
also, thanks for the help on the tank coating info.
ORIGINAL: springer_
Here's the reply I just got.... It's not a 1982 though.
We know that bike well. It's a 1984 FXR It's also the bike we did all of our testing with. We have a small book you may have seen That Jerry Branch wrote. We used that bike for all the testing.
HP that I recall was about 102 @ 80" Now that it's a bigger motor I don't know what it is. or what cam is in it.
When Dick Bought it he had all the paint work done to it,not us.
John O'Keefe
John O'Keefe
