05 fatboy trouble
05 fatboy trouble
i have o5 fatboy w/ 88" carbed when riding steady speed and twist on throttle i get a bad hesitation and then it will go. im not sure if is plugs, wires or carb. i have samson pipes and heavy breath screaming eagle air cleaner. im not sure if carb was re-jetted or not all work was done before i bought it
another problem i have is when i first get my bike out it idles normal once it warms up, but after i ride it for lil while it idles really high and sounds more like a honda w/ loud pipes. is this normal for carbed model? the others i ride w are fuel injected so i can go from theirs thanks
Start with the idle air mixture screw on the carb and the plugs. If you can see the idle air mixture screw it has been rejetted. It not, it has not. Google it up. It could also be that your carb needs to be cleaned among any other number of things but start simple. One more thing, check your battery cable connections too.
Drew
Drew
thanks for letting me rant,
JR
Samson Exhaust
