96 883 Backfiring, fouling plugs
I have a 96 883 with an S&S super E carb, and straight pipes which has been backfiring out the tailpipes, and fouling plugs. It is just starting to be ridden after sitting for the winter.
I referred to the quick guide on the S&S site, it idles pretty good, but has a problem accelerating. If I twist the throttle slow, it seems ok, but twist it quick and it kinda pauses, then pops out the tail pipe. If I give it a few quick twists, it will almost "catch up". It runs good with new plugs, but after a few miles I start having problems. The plugs are incorrect from what I have been told. They are NGK D7EA, and the bike calls for DCPR7E. Not sure how much differnce that makes. The plugs have been turning a dry powdery black. The old gas was drained out and fresh gas was put in. It runs the same with the air filter on or off.
I checked the charging system, and it's putting out about 14.5v, and the battery is a couple weeks old. The carb was rebuilt last year, and I was told that the bike ran fine last summer. I am wondering if I need to have the carb cleaned, or re-jetted. I have no idea what size jet is in it right now.
Any ideas/suggestions?
rstrydio
03-22-2014 07:02 PM
