Healthy 103" Build...Suggestions
Old 06-21-2010 | 11:27 AM
Kingofcubes's Avatar
Kingofcubes
Default options
Originally Posted by Puttnutt24
I want more!
Ok, I'd like to build this motor one final time. You can see by my signiture what I'm running now. I'd like to go alittle stronger.
I'd like to go with a 103 inch kit, step up the compression a little, stick with the stock heads, a good strong torque cam but one that doesn't fall off to quickly and get it all dialed in on a dyno useing the TTS Mastertune. I'm after a strong exhaust note. I'd like to stick with the Rineharts but I'm open to changing exhausts if it would compliment the suggested components
Can I get a suggested list of components
Thanks in advance......Rich
Are you looking for a little more or a lot more? You could have 1.900" valves installed with a little clean up and new springs, an Andrews 54 cam, and 103 or 107 inch pistons in your stock cylinders. Those pipes work well but for best torque that will pop you eye ***** to the back of your skull and sound great I like the Road Rage. I like your choice of tuning tools.
brnew
Engine Mechanical Topics
56
09-29-2021 09:20 PM
marty442
01-07-2011 06:33 AM
smokindave
11-16-2009 10:58 AM
timberwolfz28
09-10-2009 10:31 AM
bensonjv
44
12-12-2007 10:05 PM
