Can't turn motor over
Ok, I'm hoping I didn't csrew something up. Got my motor back Saturday, been working on it evenings after work. Have everything together up to rocker arms and pushrods. Was going to turn motor over to find tdc so I can start adjusting pushrods, but I can't turn engine at all. Put it in gear and tried to turn rear wheel but it won't budge. Bottom end was assembled already along with pistons and cylinders when I recieved it. When I put the clutch and compensator back on the primary chain hung down under the comp sprocket just over the edge of the primary case and I torqued it down without knowing it was in a bind. When I noticed it I loosened the comp and moved the primary chain up and retorqued the comp sprocket. That is the only thing I can think of that I did wrong. Could that be causing it not to turn over? Should I pull the primary again and recheck the comp sprocket or could there be something else causing this? Any help will be greatly appreciated, I'm supposed to have it broken in and tuned on a dyno this Saturday. Thanks
ashmarc
04-02-2010 07:54 PM
