Camshaft over lap
I think you'll be fine. It's duration suggests it's a revvy cam, relative to its lift so the top end will be good - above 3000rpm is where you want to be anyway. For idle I think it will be OK - it has LCA's around 102 degrees so the idle should be OK - I'd imagine they put it at that point to maintain an idle but to put some low end torque back in. I don't see anything to suggest this will produce bad habits in your bike although the quality of the tune will be important. Go for it and let us know how it feels.
