Stock EVO/simple mod questions
I have a 93 Softail Custom with an 80" EVO. It's totally stock other than drag pipes. Just wondering if anyone knew stock HP ratings or if any one had one dyno'd or what the rough quarter mile time would be? Just kinda curious on those. I don't really run my bike hard but just wondering.
I could use a little more power and was looking for some recommendions for some extra power. I want to start with bolt ones. The bike has 18k on it.
I was thinking maybe a carb, ignition or intake/air filter? I don't know just a whole lot about Harleys yet so I need some help selecting parts.
What would be a good carb? I think I have been told an S&S Super E or a 44mm Mikuni. How much does a cam help out? And I was told an ignition box makes a big difference too. Thanks guys!
in my 97 service manual it says 69HP for 80"evo, I put S&S super 80 kit on mine and it is a totally different bike S&S says it should be right at about 80HP but I do find that is in the mid RPM range before it really starts to pull but pull it does so I would have to say that I am satisfied, if your thinking porting be careful because the more you port the more you are in the upper RPM's you will have to go to get power.
ORIGINAL: Blown 331...I have a 93 Softail Custom with an 80" EVO. It's totally stock other than drag pipes. Just wondering if anyone knew stock HP ratings or if any one had one dyno'd or what the rough quarter mile time would be? Just kinda curious on those. I don't really run my bike hard but just wondering...
1) Get a low restriction air filter. SE, Ness, etc. Get rid of the stock filter 'box'. It's too restrictive and was designed to limit noise. Put this on, and you will have instant gratification.
2) Do some research and get a good cam. I run an Andrews EV27 in my 'glide. I think Andrews was recommending their EV3 for the softails back then. I'm certain there are even better cams out there now. And don't forget new adjustable pushrods and a Torrington bearing to replace the crap one HD put in. Major improvement that you can feel.
3) A decent set of pipes. Nothing against drag pipes, other than the noise, but there are better exhaust systems out there that make good power and the sound (in my opinion) is better.
4) Invest in a good iginition system. Dyna/Crane/SE. Anything is better than the stock HD system as it cuts out too soon.
5) Keep the stock CV carb and get it tuned. The stock CV is a decent carb on the 80" EVO. Yeah you can spend the $$$ for a Mikuni, S&S 'E', or whatever, but for that money you can get....
6) A mild port job on the stock heads. $300-400 is normal. Don't go ape crap wild. A good head man will know how to smooth them out. Might even recommend a small increase in compression ratio. Maybe 9.5:1 Then...
7) Find someone that has a dyno and knows how to tune. You'll see that the stock iginition system cuts out at around 5200 (I think) and the motor is just starting to make HP there. You should be able to rev (not sustained rpms) the stock EVO springs to around 6000 without any problems. I know that I've taken mine there a couple of times without any problems. A good tuner, with a quality dyno can make an 'easy' 90+hp and 100+ lb ft of torque, probably a lot more, with this combo. And it's very streetable and will give you very good fuel economy.
Under a couple grand and that's having someone else do the work. You'll be smiling....
enickma
Engine Mechanical Topics
12-20-2016 02:29 PM
