Loud Valve Noise!
Loud Valve Noise!
2007 TC96 Road King Classic with Thundermax Autotune, V&H Slash Cut slip-ons, Andrews 26 Cams... runs strong, louder exhaust sound than pre Andrews Cams, valves REALLY LOUD, adjustable SE push rods put in with cams, mechanic swears by Cam install and push rod replacement and adjustment... said with synthetic oil and new cams, will be louder valve chatter... but, man it's loud - worry that it going to chatter apart Put approximately 7,500 touring miles on since the job, and still runs strong, pipes clean, light gray..., doesn't burn any oil, gas mileage is fair @ around 40mpg... but man, the noise! Any ideas?
I put in 26G's 5 years ago. After the swap, my bike was quiet when it was cold, but clattered like a Shovel when it got hot. I listened to the experts and adjusted the pushrods this way and that way, added the famous Baisley spring, and tried different lifters. Nothing changed it. At first it worried me. Now, I don't even notice the noise....I spoke to several other 26 users who had the same results after a swap and who could not remedy the problem.
Loud Valvetrain!
I have almost the same issue with my 2004 FLT, Andrews 37G's, JIM's Hyrdrosolids. Adjust the pushrods and engine is quiet for about 30 mi. and then gets noisy, check the pushrods and they are loose again. Locknuts on pushrods still locked tight?? I have done this about five times now and am ready to just forget it and ride.
Got a few thousand on the scoot since the 95 inch build. After the third oil change I began to think I was hearing "clatter". Now that I am listening for it, I hear "CLATTER!" I've got the baisley spring, push-rods are in about .150", 20/50 oil, etc... you name it I've tried it. Its driving me crazy!! Told the little lady just last night that her riding days are over, because I am not riding this scooter making this kind of noise! Bike runs great! Pulls hard! Fuel mileage is fine! Oil pressure is great! Radio plays awesome but can't drown out the "CLATTER!" Going home tonight and use the wife's stethoscope and see if I can pinpoint where it is coming from. (If that don't work maybe she'll play doctor! :-) ) All friends tell me its just a Harley and to ride but I can't stand it. Friend called today and told me about a "carbon build up issue" on some builds and told me about a "water spray" in the throttle body trick that will remove it. Any of you hear of this?
Check out the newly available, I just saw anyhow, lifters from HeadQuarters and Woods. I believe they addressed this noise issur with these lifters.
I was like you for two years, about to quite riding---Put in woods lifters --beautiful silence now. Like a new stocker, quiet sewing machine.
And this with a Woods 400-6 cam now.
