SE Air Cleaner don’t fit w/ CNC Ported HTCC Heads
08-10-2006 | 08:58 PM
The SE Back plate rest against the heads before fitting over and against the throttle body; only way I can make work is to use 2 gaskets behind the plate.
Anyone else have this problem or seen or heard of this?
This is on a 06 95 build.
08-10-2006 | 09:46 PM
RE: SE Air Cleaner don’t fit w/ CNC Ported HTCC Heads
No, but a 103 kit comes with it's own backing plate... I don't remeber if a 95(6?) kit does or not.
If the backing plate seals with two gaskets, well, then, it shouldn't make any difference.
C#
08-11-2006 | 01:15 AM
Also seen the opposite - not enough room for a gasket.
BlueDragon
Fuel Moto / Jackpot Mufflers
09-17-2011 12:17 PM
jaysonL
Exhaust System Topics
11-30-2008 12:07 PM
08fxstb
01-22-2008 04:30 PM
dawg
09-26-2007 12:12 AM
GasCan
05-28-2007 09:50 PM
body ,
cams ,
cnc ,
davidson ,
harley ,
heads ,
htcc ,
httc ,
ported ,
throttle ,
tw9bg
