Help with my 103 build
I have an 07 flhx. im im the process of doing a 103 build.
When first got the bike I added Rinehart exhaust, S&S VFT/Pro Tuner, and an S&S Air Induction intake.
What I have for the 103 are KB 10:1 pistons, Feuling Reaper 574 cams, Feuling Cam Plate and Oil Pump.
I'm wondering if I should also purchase a J.E.T. 48mm Throttle Body.
Any suggestions?
Any suggestions?
It depends on what you do to your heads, i.e. valve size port size, I would stay with a stock tb as it will give better throttle responce on the street. If you are racing or dyno shootout then go with a bigger one, a larger tb will flow more air but you do need the rest to keep up with it
