Budget 95"....someone help a brother out!
Old 08-09-2006, 03:33 PM
fripple's Avatar
fripple
fripple is offline
Default RE: Budget 95"....someone help a brother out!
awesome! thanks for all of the ideas guys. I really do appreciate it. Lunch is on me.
Old 08-09-2006, 08:08 PM
springer_'s Avatar
springer_
springer_ is offline
ORIGINAL: Traceman
Very informative post. This is along the lines of what I want to do. How much more to go with the gear drive set-up? My bike has 8000 miles. Do you think everything else should be in good shape that has mileage conditions?
Sorry to rob the post
Traceman
With only 8000 miles you could get by without the mileage conditional parts. I would inspect everything and if there are unacceptable signs of wear, replace it. I forgot to mention the inner cam bearings should be changed to Torrington bearing while in there.
If we do the heads, we offer Gear drive cams for approximately $550-$600 (depends on cam selection and availability).
Old 08-09-2006, 11:04 PM
KY23's Avatar
KY23
KY23 is offline
American Iron magazine has a two part article (last month and this month) on a Twin cam 95" upgrade. Pretty good artice.
Old 08-11-2006, 01:18 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
One_Screamin_Eagle is offline
stock heads
129$ cast compression pistons
.040" Cometic head gaskets $30
bore cylinders to 1550 $130
211 cams $279
Rejet stock carb $20
Slip Ons
SE air cleaner $130
Crane HI4 module
Stock Pushrods
Will net mid to upper 80's on hp and hit 90 tq
cheap cheap cheap.
Old 08-15-2006, 01:40 AM
dhutchison's Avatar
dhutchison
dhutchison is offline
This is just my opinion, and others may disagree. To me it's worth a little extra to go ahead with a gear drive set up. An absolute must if this a bike you plan on having a long time. I had 20K on mine when I did a cam swap, and both tensioners were in real bad shape. I just took out a set of the SE203's and went with the Kuryakyn Wild Things TC2G's. I am well pleased with the results.
BikerJack69
01-03-2012 06:58 PM
slim55g
01-24-2010 10:42 PM
SUPERGLIDE2008
02-27-2009 07:36 AM
fxstb00
02-25-2007 06:56 AM
blackend
10-15-2006 10:29 PM
Quick Reply: Budget 95"....someone help a brother out!
