Do I really need to re-tune and dyno AGAIN!?
Old 03-25-2010 | 01:30 PM
sglider's Avatar
sglider
Stage IV
Default Do I really need to re-tune and dyno AGAIN!?
I just installed V&H headpipes on my 08 street glide. This is an upgrade from the stage one kit that was already installed. My stage one kit originally consisted of the rhinehart slip ons, screaming eagle air intake and having the bike tuned and dyno with the screaming eagle super tuner. The dealer said I could put the pipes on myself and ride it to the shop since it was already tuned once but recommended I get it retuned. Do I really need to do this? They want $400 bucks everytime...
Old 03-25-2010 | 02:29 PM
xxxflhrci's Avatar
xxxflhrci
Yep, if you want it to run at it's best.
Old 03-25-2010 | 02:39 PM
sglider's Avatar
sglider
Stage IV
Will it hurt anything if I don't? It's running great now.
Old 03-25-2010 | 02:41 PM
tibadoe's Avatar
tibadoe
What kind of V&H headpipes did you install?
Old 03-25-2010 | 02:42 PM
xxxflhrci's Avatar
xxxflhrci
I doubt it....If it were me, I'd install a fresh set of plugs and monitor them to make sure it wasn't running too lean.
Old 03-25-2010 | 03:08 PM
djl's Avatar
djl
No, but a dyno tune is necessary to make sure all is right with the world. You might be surprised and find that you lost some TQ; the factory head pipes are pretty good hardware. The tuners in my area that tune a bike will re-tune for upgrades and charge dyno time only since it is not a full on, start from scratch tune. Most will charge $50 for a couple of pulls just to check AFR and if that looks good, your done. Negotiate with the tuners.
Old 03-25-2010 | 11:41 PM
SEDELUXE's Avatar
SEDELUXE
yes just a pipe change you could ride it to the dealer but the afr must be checked. also your bike is a 08 do you have it in close loop or open lopp if ts in closed loop you might be fine just the way it is dont know what map they ran or started with or how good of a tuner they are . but you have a pretty wide margin if its in close dloop. i would not run it in the dead of summer but with the temps as cool as they are you will be fine.
Old 03-26-2010 | 09:58 AM
sglider's Avatar
sglider
Stage IV
Thanks all. I'm going to call the dealer and see if I can get a better deal on the dyno.
2008GLIDE
2014-2023 Touring Models
49
05-19-2018 08:26 PM
harley7316
08-27-2013 03:52 PM
Kuminatcha
02-03-2013 02:16 AM
Rlpro
09-19-2012 10:33 AM
pmedic433
03-09-2011 04:29 PM
Quick Reply: Do I really need to re-tune and dyno AGAIN!?
