Ironhead carburetor
Ironhead carburetor
I'd like to know where the hose that comes out the back of the float bowl is supposed to go to? I have a 72' with a stock HD carb from what I dont know. I traded it when I got tired of a SU eliminator carb. Anyway, I would have to say it's always been plugged. But all I can say is that there's a crusty 1" piece of hose on the barb thats pouring gas whenever I turn the gas on. Any help would be appreciated.
Hey Scott, I don't know what I've got. It has Harley Davidson on it and a weird looking fat K on the body if that helps. The numbers on it are 02blwa14 and a small tag with 0129 on it. The screws on the float bowl are bugered up and I couldn't get my screwdriver to bite but, I plugged the overflow, poured some gas in the carb and fired it up and guess what? I took the plug off and no more leak so it must of freed up the needle. If you know what carb I have it would help for future repairs. I can send pics if that would help. I have a small crack in the plastic ell where the fuel line plugs in but it only leaks if I pull down on it. If I knew what I have I could possibly replace it. Thanks for your help. Jay
That fuel inlet can be replaced with a brass, barrbed fitting that is manufactured for just that.
Scott
heres the brass inlet
http://www.jpcycles.com/product/4000165
as for your float bowl screws, use a small pair of needle nose vise grips to grip the heads and turn them out i recomend replacing them with allen head screws, the size you need is M4 .70 X 12mm for the short ones and M4 .70 X45mm for long one that goes through the accelerator pump housing, but you can buy a complete kit to replace all the sscrews here
http://www.jpcycles.com/product/4000363
