Sponsored by: Jekill and Hyde
103 build cam question
Old 02-20-2010, 11:42 AM
Jeff McKinney's Avatar
Jeff McKinney
Jeff McKinney is offline
Default 103 build cam question
Have a friend buying a '10 ultra classic & having a dealer installed 103 before he picks it up,sert,air cleaner & rush mufflers.He wants a 255 cam but i don't know what the cr on the 103 kit is,i'm afraid he may have hot start problems.If indeed that's the case,i was thinking andrews 21 or 26,but then there's the warranty issue.So that being said,any other se cam that's close?.He doesn't want to have to do cr's,offset crank gear,or any headwork etc.So 2 up,hilly-mountain type riding,bike will probably never go over 4-5k rpm,wants all the power from the bottom.
Old 02-20-2010, 02:49 PM
rhenicke's Avatar
rhenicke
rhenicke is offline
If it is a harley kit , the 255's are probably fine. I bought a se 103 big bore kit , added 255 cams later , seems fine. The stage 2 103 kit comes with 255's.
Old 02-20-2010, 04:12 PM
troop's Avatar
troop
troop is offline
I'm going basically the same route and am having manual compression releases installed. Dealer should only charge around $125 parts/labor. Just cheap insurance on some starting occassions...
Old 02-20-2010, 05:11 PM
streetclyde's Avatar
streetclyde
streetclyde is offline
Old 02-20-2010, 10:10 PM
connector's Avatar
connector
connector is offline
Just did a stage III with the 255 and i got the manual CR put in. Have put a 1000km on it and haven't had any problems with starting but its easy just hitting the CRs making it a habit soon as i shut it off i hit them.Oh ya by the way love the TQ on this build
Old 02-21-2010, 05:53 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
The warranty is only as good as they want it to be, on any given day.
Can anyone say Magnusson-Moss Warranty Act??
Install a Bob Wood TW-5-6, and enjoy the power.
Scott
Old 02-21-2010, 10:54 AM
pointerman's Avatar
pointerman
pointerman is offline
I blindly started down that same route with an 08 Ultra, and the dealer was going to install 10.5:1 CR pistons, new valves, etc. More research on my part led me to believe that on a 900 lb. bike I would be better off and have less heat generation with 10:1, 9.9:1 more precisely after head work. Using Woods tw7h cam. The build is in progress. There's a lot more knowledgeable folks than I on this thread, but I think your friend should ask about the intended CR for his 103 build.
Old 02-21-2010, 11:34 AM
djl's Avatar
djl
djl is offline
Received 2,211 Likes on 1,602 Posts
Install compression releases or select a different cam.
Old 02-21-2010, 11:35 AM
Hobe's Avatar
Hobe
Hobe is offline
Just finished a build almost identical to this, only thing that might be different is head work. My build is an 08 FLHT using AMS 105 components, static set at 10.2:1, running the 7H, the heads were ported, 1.9 intake, upgraded springs, and AMS ceramic coats the exhaust runner for heat reduction in the head. I had them add manual CR's to make sure all was well in our summer heat.
I think you will be happy with your results, so far I am very pleased with overall performance. I will say I have wondered if the 7H is really any more effective than the 6-6 in a similar build, but guess I will have to keep wondering.
Hobe
Old 02-21-2010, 12:02 PM
pointerman's Avatar
pointerman
Thanks Hobe. I don't want to hijack this thread, but I did want to say it's nice to hear you're happy, as our builds will be almost identical.
Quick Reply: 103 build cam question
