'78 Sporster won't stay running
I have a 1978 Sportster that will almost start. It fires exhaust out the back for a second or two, but then it immediately cuts out. It doesn't want to run for more than a second or two. Anyone know what the problem could be? I just got a new ignition coil and spark plugs.
Received 1,297 Likes
RE: '78 Sporster won't stay running
Ok, go back to the basics. Maybe a wire has come loose or disconnected from the coil install, pull the plugs and see if you're getting any fire, you could have fouled a plug, and just because a plug fires out of the cylinder it still may be fouled and not fire under compression.
Do a compression test, both cylinders should be within 5-10 pounds of each other and I'm not sure what the compression should be for the sporty, I'd guess at least 150 lbs but thats a guess.
Pull the fuel line off the carb and make sure you're getting fuel to the carb, if you have fuel, compression and fire it should run. If the compression is good, and you have spark and fuel to the carb and it still won't run then you might have trash or water in the carb.
Let us know what you come up with.
John TN
John TN
