Slow Idle Jet Screw
Slow Idle Jet Screw
I think it's called that. It's located on the bottom of my carb. I have a '93 FXLR with the obligatory Kiehin CV carb. I rebuilt the carb the other day, but when I put the "Slow Idle" screw back in, I didn't pay any attention to how many turns in or out. I just screwed it in 'til it stopped. Of course, that's not correct. It needs to be backed out, but how far? Can someone tell me how many turns I should back it out? (it's probably in increments of 1/8 turn). Once I get it out to a good starting point, I can fine tune from there.
Thanks
Thanks
Well, I went home last night and screwed the thing all the way in, then backed it out 2 1/2 turns. Now it won't start. As I stated earlier, I rebuilt the carb and when I replaced this screw, I screwed it back in the same number of turns I had used to remove it. Tuesday when I re-installed the carb, the bike started right up. As stated, I did have to keep the enrichener **** out for it to run, but that was only 'cause I hadn't set the idle screw. I shut it down and re-started several times. Worked fine. Now, at 2 1/2 turns, it onl hits a little like it wants to start, but doesn't start. When I twist the throttle, then it acts like it wants to choke down or something. It stops trying to start - won't even hit. But let the throttle alone, then it starts trying to hit again. Now what have I done? Any suggestions?
Thanks
Thanks
Make sure your air/fuel mixture screw is put back in this order. Slide the spring on the air/fuel screw first, then the metal washer and last, the o-ring. The o-ring should be the last thing installed onto the air/fuel screw. Don't bottom out the screw too hard either. Just bottom out lightly, then turn back out about 2 turns.
