Advice needed from the cam experts
Old 01-23-2010 | 10:04 PM
fripple's Avatar
fripple
I'm running the SE204 in my 09 FLTR. I got 82hp/99tq from it. I like the cam so far, it really woke up the bike.
  #42
Old 01-24-2010 | 11:26 PM
thewholehog's Avatar
thewholehog
Fripple thats some nice numbers!! what kind of manners does it have and what's the bottom end like? ie when do the cams come on and are they peaky?
Thanks for the feedback.
  #43
Old 01-25-2010 | 10:20 AM
fripple's Avatar
fripple
Here is the dyno sheet. As you can see my AFR isn't perfect. With a better tune and a 2-1, I probably could pull some better numbers....
  #44
Old 01-25-2010 | 04:29 PM
thewholehog
Thanks for posting your dyno chart, it has a pretty nice TQ curve.
  #45
Old 01-31-2010 | 09:03 AM
troop's Avatar
troop
Wonder how the 204 would work with a .030 gasket and the tad bump in CR it'd get ?
  #46
Old 05-03-2010 | 02:13 AM
thewholehog
Originally Posted by Dalton
....... I have run the Woods 6 in a couple of bikes and builds I have done for others and it is also a good cam but I do not like running an advance key when there are so many others out there that are truly bolt ins that are ground to work well with stock compression.......
Hi Dalton, you said there are other truly bolt in cams out there instead of needing the adv key with the woods...
which ones do you specifically suggest??
Do they work without losing bottom end TQ?
Mac10
06-02-2016 05:45 AM
FLTR2008TRIKE
02-02-2013 06:08 PM
SmittyFXDL
03-19-2012 06:54 PM
cnnesseth
11-30-2010 10:13 PM
HGM
EVO
21
01-15-2010 09:09 PM
Quick Reply: Advice needed from the cam experts
