Vance and Hines FulePak
hello
Guys I need your help!!!
I've got k&n filter + v&h sideshots + v&h fulpak. the problem is the dealer told me that they will cancel the engine warrenty if i install the fuelpak. so what can I do??? cuz i know the dealer , if anything happened to the bike even if it has nothing to do with the fuelpak they will say it's because the fuelpak. the question is can I install the fuelpak at home and save the engine warrenty, and then if anything happened I simply remove it and put the stock one. CAN THE DEALER KNOW FROM THE COMPUTER OR THE CONTROL UNIT THAT I DID SO.??? CAN THEY CATCH ME???
HELP AND advice is so much appreciated!!!
Ive tried a few fuelpaks,Its just my opinion but I think for most driving conditions on 07 or later models (closed Loop) a fuel pak is worthless, however install takes about 10 minutes and removing it even less, There is no stock one its just a processor that mounts between the OEM ECM connections, they do not leave a footprint so ignore your dealer , if you breakdown you can pull it off on the side of the road if need be.
