Boring 88 to 95 cost
also remember that fuel pack that you are running has to go.
you will need a TTs and the break in map better be close or you will screw up the rear cylinder from a lean condition.
Scott will tell you all this as a matter of fact he will explain it to you in detail. you will need a break in map for the build.
and a good tune.
and a good tune.
