Dollars/HP increase?
Fellow members BAGGERDSM, Dalton, PhilM, all have extremely reliable rippers that they tour with.
Those bikes will flat wax a Jap sportbike at 65-70 mph, both pulling high gear roll on throttle runs. Plain fact.
Sure, after the 4 cylinder, overhead cam, 5 valve, multiple t/bodied,(and solenoid controlled intake tracts on some) factory tuned pipe, vaiable ignition timing, lightweight machine finally gathers a head of steam, it'll roll around those bikes. And.............?
Wendover, Utah is a great place for those.
Scott
Scott
Scott
Scott
I made the proper edits to that post.
Scott
...but, do I get to .... wait, I mean wouldn't "you" add the results of the (multiple) previous iterations???
If you're not have'n fun with it..... find sumthin else to do. HAHAHAHAHA!!!!!
also.... I have a feeling Scott has a scoot or ten what would fall into the "group" referenced earlier....
+++ on the $80-100/hp for the first 20 (50-60 if you do the work yourself). After that it adds up.
I don't think that most HD owners try to get their torque/HP up in order to drag the rice burners/sports bikes. It more of a culture kind of thing.. some do it for bragging rites amoungst other HDs and some do it just to have a feeling that their bike can perform. I did cams and Stage I only... why.. part was just hanging our on the Forum and got an itch that needed to be scratched. But I do like the wump-wump of the new cams and the little extra low down grunt. $89/hp.
i ride with a lot of guys that have sport bikes and harleys. when i first went riding with them i had a 98in motor. they fried me. im talking 600 here nothing bigger ok... then next yr a 120. got real close
this yr i di a bunch of suspension and other things.
did not tell them as. went up north took it real easy... when we got up there they were amazed how a harley could stay with them all day long. now like i mentioned before up to 120-130 mph . ill cruise at 100 mph all day
like another fellow member states no hd can run with those bikes and he is correct. those machines do what they do very well and stop handle on a dime.
if i had to build a motor again i do not think i would go this radical. its very costly but fun.
now i am gettin older and looking to do something diffrent.may be a little over stock..... as a fellow member keeps tellin me when i talk to him all he says is YEA RIGHT STOCK ....once ya go big cubes you never go back.
George,
Next will be, I have the wrong color shoelaces on, or something else that means as much.
I'd be pretty shallow, if I put a lot of stock in what those fellows over there busy themselves with.
Everyone that matters, knows what is going on anyway.
Scott
Scott
