Gear whine after cam replacement
98 Evo 1340
Due to lifter failure, I replaced my old VThunder EVL-3020 cam with a new one (same part number) because I was pleased with the grind. I re-used the cam gear from the original 3020 so I didn't bother to pay close attention to the clearance between the pinion and cam gear upon re-assembly. I now have fairly substantial gear whine but had none before replacing the cam. I *suspect* this is due to differences between the centerline of the original outer cam bushing and the new one I had installed by a reputable local indie.
My question: Is cam gear whine something I need to worry about, or can I just leave it be without fear of serious repurcussions? The noise isn't bothersome.
Thanks!
Thanks!
If it makes noise hot or cold then you might want to change something. If your running both gears the same and now you have noise then it's probably the new bushing. You might want to check the dimensions with the three wire method and order the next smaller crank gear. It's the cheaper of the two to replace. You will need the proper diameter wires and the micrometers to do this. I know of nothing you can shim to change anything. If you had a lifter failure you might want to check both gears for tooth damage too. I rebuilt a friends bike due to lifter failure and had metal all over the cam cavity. Make sure you get the right gear combination or you'll wine or tick.
Also, thanks to advise from Scott (hillsidecyclecom) and Kirby (prodrag132), I very thoroughly inspected both drive gears and the oil pump for lifter fragments. I also thoroughly cleaned the cam chest and the oil passage from the chest to the pump.
Harley uses a two wire method and it is described in the factory manual or at the Andrews link here:
http://www.andrewsproducts.com/PDF_files/CamEV80.pdf
The last page has the method and the color charts. Basically measure the cam gear and use the chart to see the size of it's mating crank gear. Measure your crank gear and you should see it's too large. If Andrews makes one that will work I would buy it rather than a Harley one. Hope that makes sense to you.
Interstingly, the install instructions that came with the Comp Cams shaft I bought said to test the lash by putting the cam (with gear) in place and slide of side-to-side: resistance should be present, but it shouldn't be excessive. Seems like a little too "shadetree" to me.
Took it to a reputable local indie and just said "wanted to have you give a listen to my valve train and tell me what you think." he didn't even notice the whine, and once I pointed it out he said it was fine. Without a lot of experience, it's just hard to know what's too much noise and what's not.
Thanks for your help.
