Ive posted you few times on here and
figured I would ask a few more questions, I have a 05 ultra with Rinehart true duals and Im thinking of doing a stage 2 kit , bored out jugs,wiseco pistons , woods tw-6 with heads ported and polished and a pc3. should get killer numbers on the dyno with this set up, their saying close to 100 on both. It may be alil more money than I want to spend.
I was also told that I could get decent numbers with just the woods cams and the pc3.
Has anyone else done either of these 2 set ups and if so how do you like ??
thanks
thanks
polished heads mean absoluty nothing
the power is in the porting not the polish. i have taken off a lot of heads and never took a set off that were polished after miles of riding they all had carbon on them so polishing is only good to look at.
alos 100/100 everything better be set up correctly. you are not going to bolt it together and acheive those numbers .
heres a solid build
Baisley super street heads
andrews 37 g cam
flat top pistons
9.6 compression a little over 100 100i know this will get ya
heres a solid build
andrews 37 g cam
flat top pistons
Go with 98" pistons, have your cylinders bored to match, send out your heads to be ported, polished, CR installed, CC'ed and milled for approx. 10.2:1 CR, make sure your deck height is at "0", and get a good tune done...........and you should break 100/100 for peak numbers.
The whole package has to work together............and the tune is very important.
www.bigboyzheadporting.com is who I use for my head work and my dyno tuning..........highly recommend Bean to anyone.
Steve
Steve
Steve
jag1886
10-12-2007 11:34 AM
