Sponsored by: Jekill and Hyde
Woods TW6-6 cams in touring bike - 4* advance gear?
Old 11-20-2009, 05:10 AM
thewholehog's Avatar
thewholehog
thewholehog is offline
Originally Posted by Hillsidecycle.com
Yes. The manners of the bike are very stock-like, but with the fun-factor is waaaay up.
Scott
Thank you
Old 11-20-2009, 09:13 AM
djl's Avatar
djl
djl is offline
Received 2,224 Likes on 1,609 Posts
Originally Posted by thewholehog
Ok thanks for the advice. Are the Andrews EZ install pushrods actually "EZ install"? and would you recommend them? and also will the stock pushrod covers work with these pushrods? or will I have to buy aftermarkey pushrod covers?
Thanks again.
I have never used the Andrews PRs but believe they can be installed without removing lifter bore covers or rocker supports; a call to Andrews will confirm.
The stock pushrod covers will not work; you won't be able to adjust the pushrods properly. You will need the o-rings, tubes and clips to get H-D parts or purchase a "kit" from the aftermarket.
Old 11-20-2009, 09:33 AM
maineultraclassic's Avatar
maineultraclassic
maineultraclassic is offline
I bought a set of Andrews EZ adjustables when I did my first motor build, and they wouldn't fit with the motor assembled. They were about 1/4" to 1/2" too long when fully compressed. That is why I'm using the SE EZ install adjustables.............needed a set quick and the local HD dealer had them on the shelf.
Steve
Old 11-20-2009, 10:53 PM
thewholehog
Steve
Thanks Steve - I ended up going with the S&S adjustable pushrod kit which comes with gaskets, o-rings and pushrod covers.
SmittyFXDL
04-07-2018 09:19 PM
Varooom
12-31-2015 07:55 AM
producer
05-01-2013 06:13 AM
drakenkade
09-20-2010 12:11 AM
Road King Kid
12-24-2009 10:55 AM
Quick Reply: Woods TW6-6 cams in touring bike - 4* advance gear?
