Sponsored by: Jekill and Hyde
compression test results
Old 11-07-2009, 04:42 PM
riskyfool's Avatar
riskyfool
riskyfool is offline
Default compression test results
I have a 2002 lowrider that I did a Head Quarters Dyna Sport package rebuild to. After one year I have just put on 10,000 miles since the rebuild. Just checked compression. I wish I would have done a compression test immediately after the build to have a point of comparison, but I didn't.
Both cylinders are at 220 psi exactly, then both are at 240 psi exactly after adding 1/2 oz oil. This build is rated as 11:1 compression.
My factory manual says anything above 90 psi is ok and if there is a significant jump in psi after adding oil it is an indication of worn rings.
Questions: Obviously my manual's specs are for a stock bike. Does 220 seem appropriate for 11:1 compression?
Also, assuming 220 is reasonable, is the 20 point jump to 240 psi significant or am I ok there?
Thanks for your opinions.
Old 11-07-2009, 05:31 PM
rbabos's Avatar
rbabos
rbabos is offline
Adding oil will always raise the numbers some. Doing a leakdown test warm to hot engine to show what's really going on, but it sounds excellent to me. As for 11-1, don't know but you are up there. Not a lot of point on checking a new engine for leakdown or compression, since it's not seated . Once broke in is the best time to get the numbers.
Ron
Old 11-07-2009, 06:06 PM
riskyfool's Avatar
riskyfool
Thanks rbabos. wouldn't 10k on the rebuild be considered broken in? 26K total on the bike.
Old 11-07-2009, 08:49 PM
rbabos's Avatar
rbabos
rbabos is offline
I meant I would have checked it at about 1k for a baseline, so you missed it big time.
Ron
Old 11-07-2009, 09:00 PM
Dalton's Avatar
Dalton
Dalton is offline
Your CCP will depend on static (11.0:1) compression and then the cam you are running. Earlier intake close, higher the CCP.
For a HQ build at 11.0:1 and a cam such as the HQ0039, your CCP is right in the ballpark.
Old 11-08-2009, 06:57 AM
riskyfool's Avatar
riskyfool
Thanks Dalton. For a cam I have the HQ0033 (tornado) - gear.
Old 11-11-2009, 08:16 AM
riskyfool's Avatar
riskyfool
Another question: forgive my ignorance, but what is the difference between CCP and PSI? What is CCP? I don't have it with me right now but I could swear my compression gauge measures PSI.
Old 11-11-2009, 01:41 PM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
You are measuring cold cranking pressure in pounds per square inch.
Old 11-11-2009, 03:06 PM
riskyfool's Avatar
riskyfool
Thanks very much.
Old 11-12-2009, 06:23 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
What kind of gas do you have available in your area??
Scott
Quick Reply: compression test results
