Your CCP will depend on static (11.0:1) compression and then the cam you are running. Earlier intake close, higher the CCP.
For a HQ build at 11.0:1 and a cam such as the HQ0039, your CCP is right in the ballpark.
Hi Dalton,from what I've seen, those HQ builds run quite a bit higher in the comp than most builders are recommending,they must have a pretty efficient chamber design to avoid detonation.How high can the ccp go in those heads before running into problems?
