engine ticking
RE: engine ticking
My just normal has turned out to be a wrist pin problem and a misadjusted adjustible pushrod. After weeks of just normal I carried it to a second wrench who diagnosed it in 10 minutes. If nothing else, seek a second qualified opinion. If it's nothing, y're out a few bucks, if it's something, you might have saved yourself a bundle.
Good luck
Bubba
Good luck
Bubba
RE: engine ticking
You bring up a common issue with our TC88's. You will hear man opinions and what it is, what it could be and what to try to tame it. First, what oil are you running? What part of your engine is it coming from? Does it get louder with RPM's? There has been lots of people who have changed out the oil pressure relief spring (Baisley spring) and this simple mod fixed their ticking noise. This stiffer spring allows oil pressure to increase about 5 to 9 PSI which gets more oil up to the rocker boxes silencing the ticking and other "normal" noises. This spring didn't seem to change my ticking. Mine is liklely something else. I put this spring in in about 2 hours, it's in the cam plate. And yes, alot of Harleys just make noise. and it is normal-sometimes
Antmf
08-23-2013 03:10 AM
