Mikuni HSR42 problem
When the motor is running, gas runs out the vents on the carb. Kind of an all of a sudden problem as the bike has been fine prior. The first time it occured I tore down the carb as I figured it was a bad needle-seat assembly. There was no visible dirt, it has clean fresh gas and it is ridden regularly. I noticed like a discolored ring on the rubber tip of the needle and upon reassembly I reversed the position of the needle on the float tab. Took it for a spin and it was fine then started it up again a few days later and gas again is flooding out the carb vents while the motor runs. The bike is an 02 EGC. I am going to replace the needle-seat assembly but can someone with more experience offer any other ideas. Thanks in advance. Ride Safe. Doug
42, coming, float, flooding, fuel, gas, hsr, hsr42, issues, mikuni, needleseat, problem, troubleshoot, troubleshooting, vent
