Sponsored by: Jekill and Hyde
What does engine knock sound like?
Old 08-19-2010, 09:18 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Gotta believe that timing, or rate of advance, needs to be pulled back a tick.
Scott
Old 08-20-2010, 02:41 AM
Stylz's Avatar
Stylz
Stylz is offline
4th Gear
Originally Posted by leadsled70
I know this is an old thread but I will try anyhow. Stylz, did you ever figure out your peoblem with the engine noise?
Yes, the consensus I get from everyone is turn up the radio, or buy louder pipes!
These are air-cooled ancient machines in a way, and thus, do different things at different times, for no rhyme or reason to the beginner.
What I can say, with more specificity is, the bike definitely runs rougher in 1st gear (pulling away from a stop) when it's hot. It's not a small difference. I assume it has something to do with some metal bits swollen in the heat, and not 'sliding' as easily as they should. I have to use more throttle to get it to go, and not bog down or stall.
It's very predictable -- it only does that when the bike is hot, and I'm starting from a stop. At the same time, in the same conditions, if I turn the bike off, and try to start it again hot, the starter doesn't turn very well. I first thought the battery was toasted, until I started noticing the 'hot' correlation. Anytime the engine's real hot, the engine doesn't turn over well; it starts every time (so far), but it feels like it might not.
Good luck,
]{evin
kylebryan
05-03-2016 10:46 AM
aces25
01-21-2014 07:43 AM
Krazyshark
Ironhead
01-23-2012 07:51 PM
AdrianVall
02-06-2009 12:01 AM
UH60Hwkdrvr
10-15-2008 07:39 AM
Quick Reply: What does engine knock sound like?
