95 build
95 build
just completed 95 repair build, on a 05 FLHTCI.due to a oilpump misalinment,scroed everything in cam cheast, so might as well go bigbore "light" SE95 cylinders,SE flat tops,SE 203 cam.new SE billet cam plate, SE oilpump, SE aja pushrods, and lifters,stock heads, stock head gaskets and sert tune, V&H true duels. .003 T.I.R. on crankshaft pinion.Motor came in at 77hp with 88tq.cam comes on at around 2600rpm falls like a rock at 4000rpm,does this seem about right,with this combo.Planning to do a little work on the heads this winter,What can i expect and would it be worth head work with this setup.
So what your saying randy is that just by going with R&R stg5 heads on his build he will pick up 40hp and 30ftlbs of tq?
Thanks for the info.I have the SE 204 cam,not 203.not much diffrence,One thing that i was wondering about,is when i had the cam chest apart,The lifter pockets were machined for a higher cam lift.Buddy said he had not seen that before on a stock motor,I bought the bike new .Has anyone seen this before on a stock 88 motor from HD
