fuel mixture screw
06-04-2006 | 12:51 PM
fuel mixture screw
I think my bikes previous owner screwed the fuel screw down too much. What kind of problems will it cause and can i replace anything to fix it? Thanks.
06-05-2006 | 09:12 PM
RE: fuel mixture screw
anyone?
06-09-2006 | 08:25 PM
you should be able to just replace the screw.
that should have been the only part that was trashed.
if it is messed up on the inside then i think your looking at a new carb.
06-09-2006 | 09:34 PM
thanks!
06-14-2006 | 08:07 PM
You can crack the carb throat or damage the screw seat which can give you problems adjusting the mix. Lightly seated is the way to go. The screw is difficult to get from HD (not a listed part), go to a Kawasaki dealer, some of their dirt bikes have a CV40 with the same screw and spring
06-14-2006 | 09:40 PM
i think ill just get a extended screw. thanks
06-15-2006 | 12:10 AM
Try this!
www.directparts.com
Part# cp005 its a adjustable idle mixture needle very EZ to adjust with a knurled ****
Ride Safe!
Bill Mills Jr.
Carburetor Related
08-01-2016 01:33 PM
fatrat440
08-13-2013 06:03 PM
hdbeggs
01-29-2011 10:57 AM
oil leak
Exhaust System Topics
08-30-2010 07:39 AM
slowMtnRider
05-16-2006 02:36 AM
