I need to remove my gas tank on my 94 Softail and can't get the acorn nut that sits on the speedometer housing off. It just keeps turning and I can't get my hand under it to see if there is a nut. Can anyone help with this issue?
On an 05, there is a long carridge head bolt attached to a plate on the tank. It has a square piece under the bolt head that is suppose to catch into a square slot. If it is spinning, I would try to pry the dash up GENTLY, while turning the nut.
On my '99 there is a bent spring piece of steel which has a screw and nut coming up through the speedo housing. My nut kept coming loose so I put a spot of loctite on the threads and ran into the same problem as you... I was able to reach up under the housing from where the tank pad was with a pair of long needle nose and hold the screw enough to get the nut off. I put that jam nut on the screw on extra tight with red loctite...
