High altitude carb adj?
Old 08-10-2009 | 06:33 AM
glideridemike's Avatar
glideridemike
Default High altitude carb adj?
I am located in an area at about 1000' of elevation. I will soon be riding just west of Denver at elevations upwards of 12000'. I have never messed with carb adj on my HD, but I've been told going to higher altitudes might require some carb adjustments. Anyone here familiar with this and how I could easily make this adjustment knowing I will soon (within a day or so) be back at the lower elevations?
Running a stock TC88 in my '03 WG with a 2-1 pipe and a stage 1 kit.
Thanks
Old 08-10-2009 | 07:12 AM
nvsteve's Avatar
nvsteve
I wouldn't worry about it. The CV carb does a pretty good job at altitude.
You will notice some loss of power and maybe some rough idle but it's only going
to be for a short time.
Old 08-10-2009 | 08:38 PM
mtclassic's Avatar
mtclassic
I have been from Sea Level to 12,000 feet with my cv carb and never any issues.
Old 08-11-2009 | 06:29 AM
glideridemike
How about mpg's, do they suffer much at higher altitudes? I know climbing the grades can effect it, but how about the thinner air?
Old 08-14-2009 | 03:57 PM
mtclassic's Avatar
mtclassic
you will actually get better mpg at elevation all else being equal.
Old 08-15-2009 | 08:40 AM
glideridemike
Whoddathunk....thanks
Old 08-16-2009 | 03:23 PM
Buddha4's Avatar
Buddha4
You'll notice a bigger difference going though IA and NE with the ethanol blends.
Old 08-16-2009 | 04:32 PM
glideridemike
Actually only cutting thru the sw corner of Neb into Kansas. Staying out of Ioway and Nubraska amap
Old 08-16-2009 | 06:33 PM
Jim Kraft's Avatar
Jim Kraft
It will run a little richer at the lower density altitude, but that is better than leaner. There is just no air up there. LOL
kansasroadking
01-20-2024 09:42 PM
pacman552sd
Carburetor Related
06-03-2015 10:39 PM
gaillarry
Carburetor Related
02-26-2009 07:04 AM
t059736
04-10-2008 08:45 AM
Beeracuda
13
12-27-2005 03:16 PM
Quick Reply: High altitude carb adj?
