Doherty air cleaner set with S&S plate
Is this kit work well/fit 08 FXDL?
I'm looking for something S&S tear drop style, and I found this!
http://www.dohertymachine.com/produc...products_id=25
Do I need to install after market ignition system after this?
Thanks
Thanks
Thanks
Thanks
No, you should not need to install an aftermarket ignition system to use this. However, if you have a freer flowing exhaust and add this then you will want to install a new map in your ecm.
Bart
what is "freer flowing exhaust"? and install a new map means purchase something like Twin Tec?
