Exhaust wrap is HOT!
Old 07-17-2009 | 05:33 PM
aaron8771's Avatar
aaron8771
Question Exhaust wrap is HOT!
Last spring I wrapped my shortshots with DEI exhaust wrap from Advanced Auto. It turned out great and really like the look. Only problem is it's really hot on my leg. And if i wear shorts, it's almost unbearable. I don't want to put the heat shield back on but might not have a choice. My question is, can I put a second wrap over the first one to help with this? I've also considered a couple small flame heat shields right where my leg is.
Old 07-17-2009 | 06:58 PM
Old Gunny's Avatar
Old Gunny
What could it hurt.
Remember it is coming out of the head at about 1300 Degrees F. It's gonna still sizzly if you touch it with the human body parts
Old 07-17-2009 | 09:49 PM
SEDELUXE's Avatar
SEDELUXE
Jet hot coating ...then put the wrap on it.
http://www.jet-hot.com/motorcycles.html
Old 07-17-2009 | 11:53 PM
duh
Guest
Posts: n/a
Put the heat shields back on. And Don't wear Shorts!
Problem Fixed.
Old 07-18-2009 | 04:23 PM
SEDELUXE's Avatar
SEDELUXE
Problem Fixed.
thats the easy way.........
Old 07-19-2009 | 09:40 AM
aaron8771's Avatar
aaron8771
Problem Fixed.
Thanks for the helpful information. Got another question for ya duh. My turn signal is burnt out, should i replace the bulb?
Old 07-19-2009 | 11:32 AM
SEDELUXE's Avatar
SEDELUXE
hand signals
Old 07-19-2009 | 10:30 PM
duh
Guest
Posts: n/a
Naw You got to stick one of your fingers in a wall socket then touch the burnt out bulb. That should fix all your problems.
Old 07-19-2009 | 10:34 PM
BoomerBob's Avatar
BoomerBob
You could always paint the heat shields black (or partially black) and put 'em back on.
Deftone5
06-14-2022 03:03 AM
Jersey Drew
10-24-2014 10:43 PM
sbeast
06-23-2014 06:25 PM
lateralus
05-30-2012 07:59 PM
JDixon
03-04-2009 01:15 AM
Quick Reply: Exhaust wrap is HOT!
