I know another 103 build questions
Hello , im still fairly new here and new to harleys . ive been reading tons of people's builds trying to get an idea where i need to be ... first off i have a 02 Softail EFI tc88 basically stock with a Power Comander and V&H slash cut shorty pipes with 54K miles .. i dont do alot of traffic riding mostly in the mountains and highways and im constatly in the upper RPM's .. i have bounced the rev limiter quite a few times so i kinda want a mid to upper torque range with streetability .. i do ride in toys for tots during the winters n stuff so thats bout the only time i will be lugging it down ..other wise im a mid to upper rpm kinda guy... i do want to keep dependability a factor here but i am a hot rod kinda guy (raced flat bottom v-drives boats)so i like power (torque) and lots of it..
heres what im doing im takin my 88 inch and putting a SE103 stroker flywheel kit in my cases and big bore cyl's .. looking to run about 10.0-10.5 to 1 CR or what i can get away with on todays 91 octane gas .. buddy that builds custom bikes said he can port my heads to flow really well for the build im doing and some other fancy stuff like making the valves bigger ..what i would like to know is some cam profiles i may like .. would like a torque curve that pulls hard from about 3K-6K+ .. i later plan to add a bigger throttle body if needed. i dont mind using high lift cam profiles and changing springs long as they have a decent streetability to them .. this is why im askin for some help . i ride fast and hard and nostly alone , with a passenger i do slow down to normal cruising .. mine is not a bagger either, pic below is .. let me know some combo's you guys are running ,pistons ,cams , with stock ported heads and stroked crank (103) . thanks in advance , Bill
Here is a dedicated engine combo that'll get you going WITHOUT splitting the cases.
Bore your cylinders to 98" using Wiesco pistons.
Bob Wood TW-6G gear driven cams.
GOOD set of heads.
Bore your t/body from 41-46.5mm.
Good exhaust.
Tune.
IF you are dead-set on the 4 3/8" arm, then you can bore to 107" with the correct Wiesco's, and use the Wood 8 cams.
Straightforward, easy assemblys, that deliver large, broad power.
Scott
GOOD set of heads.
Good exhaust.
Tune.
Scott
options
Yes call Scott at hillside. Scotty stands behind all of his work and i know for a fact he has a few of the competors heads up at his shop as we speak fixing those as they did not stand up too well.
a 98in kit from hillside and a tw8 cam will really rock when you call Scott ask him about the heads he just repaired and tell him you want him to do a set just like those. but to stay together of course......
i talked to my builder today and we were thinking i possibly had a bad flywheel but its not coming from my engine its in the clutch so im not doing a stroker kit im gonna just go big bore now . i see lots of 95 kits out there and a few 98 kits then i came across a 100 kit thats 4.00 stroke 4.00 bore .. now i was curious are the cases bored big enough stock to accept a 4.00 bore piston? cause if so im thinking of going the 100inch pistons and have jugs bored to match or ?? im piecing the kit together so trying to find pistons and my engine builder has a guy to bore the jugs to what i decide to go with.. just need to know my options on the 98/100 pistons in a stock case if they will work or not . thanks again for the input so far guys ..
i wish this was as easy as building a big block chevy lol .. i had a rockin lil boat i build a 700hp 470 incher full roller motor . im just glad these harley's are cheaper to build i had about 17K into motor when all done and finished lol
