Bearing puller, feeler guage(or dial indicator) torque wrench, SHCS wrenches, cam shim(s),assembly lube.
That swap is a piece of cake.
If you get caught in a snag, call, and we will walk you through it.
Happy to help.
Scott
Happy to help.
Scott
Thanks Scott.
Do I need the Crane Cam installation tool? I plan on getting the Crane 310-2 cam (less gear) and using the original gear - or is it easier to get the cam with gear??
Also, would you recommend getting retractable/adjustable pushrods?
Its a brand new motor so it is sitting on the bench (not in the bike) so working on it will be a bit easier.
