installing samson baffles
i have 33 inch samson fishtail pipes on my 03 roadking0 the pipes are wide open and I just got the 10 inch samson internal baffles I"m going to install them to reduce some noise and create some back pressure- the baffles are like cheese graters- they are rough / sharp in one direction and smooth in the other direction. There is a screw hole at one end of the baffle that serves to secure it in place once it is inside the exhaust pipe- does anyone know which direction the baffle should be mounted in the exhasut? Rough edges of the baffles towards the heads or towards the rear of the exhaust pipe?
Through the slip on open end I would imagine. Let me know how this works out and how your sound changes as I am curious about this and have had quite a few people ask me how this will change the sound. Obviously it will muffle it a bit, but they wnat to know if the decel sound will cease to exist.
the end that has the rod through it goes in first. your pipes should already have two holes for the baffles the secure it.
it will really help you if you prep the baffles. a little fine sanding, any imperpections that raise up, will cause some resistence. a little w/40 helps. i made a steel scrap pipe that i put a 1/4 or so indent so you can minipulate through the baffle in its final spot. if you dont its hell to get it out or even twist it.
hope that helped??
larry
hope that helped??
larry
Mr.Softy
06-09-2014 10:07 AM
SoCalSoftailSlim
12-17-2012 06:58 PM
tmitchellof PG
Exhaust System Topics
10-31-2007 05:49 PM
