Lifter Noise/Ticking
Hello all,
Just got done spending the last hour or so reading old posts on ticking sounds and lifters. I just finished a 95" build with mild head work, stock valves, Woods 6 cam, and converted to the 07-09 hydraulic tensioner conversion kit. Bike is running real well, oil pressure good and seems to be running cool, but there is now a much louder "lifter noise" and ticking where there wasn't before. I am not alarmed, but would like to reduce the noise if possible. During my build, I had my indy put in the new SE Tapered Adjustable Pushrods. It seems the noise is mostly coming from the front. Would adjusting the tapered pushrods help with the noise? How do I do it, if I may ask? Is it easy to pop the covers off and just turn them maybe 1/2 turn at a time? I'll take a further look at the knowledge base (great feature), but advice in the meantime would be greatly appreciated.
Ted
Ted
I have chased this a lot. My noise comes from the top end. Lifter area and bottom end is quiet while running.
I have verified all the top stuff is as good as I can get it. You name it, I have checked and adjusted everything I could think of including everything anybody has ever suggested.
I think some of this noise, ticking sometime borderline clatter, at some RPMs (maybe resonance vibrations) is valve closing noise.
I have though about it and though about it.
Nomatter how you control all this the system has just enough slack to close the valve with a little noise. The last little bit. Particular with Woods cams which are fast up and fast down.
Bob Woods even suggests targeting with a stock lifter 0.050 in. down instead of 0.100.
Above is a mind fade. Meant to say go down 0.150, instead of 0.100, to target "0.050" from the bottom. For normal riding. No overrev. Real sorry about that.
This has worked for me to a great extent.
I've got the same type noise that seems to be comming from the top of the engine. Planning on pulling the covers to check the rocker shaft end play as I've heard from several here that excessive endplay can cause noise. My motor has 68k on it, so wear is a possibility.
Re'
Having chased top end noise for years, I have finally thrown in the towel and just ride it, although this build is the qietest I have done in a long time. The Woods cams have fast ramps and will exaggerate any lash in the valve train. That being said, yess rocker end play can also add to the overall noise but really not an identifiable single noise , at least from what I have found. I have also found that if a compensater has any lash, springs getting weak, etc, the noise will travel and in all likelihood, sound like valve train noise.
Try sitting on top of a chevy 327 or 350 and ride it down the road, you will hear ticking, slap and all kinds of other noises. If it is not reeeeaaally loud, it is most likely not excessive, just an annoyance to you.
I run the Wood 6-6 and have the same noise. It is annoying at first. It seems to get louder when the rpms increase - so I up shift and the noise goes away. When I get on it, I can't really hear it. I've heard that running a straight 50 weight oil and setting the lifters down helps, but I am used to it. On my bike the noise decreased after some miles too.
Thanks all for your experiences and perspectives. I'm going to check with my builder to see if he recalls where he set the lifters, just for my knowledge. Valve springs are new, so hopefully no issues there. I have been riding with my windshield more this spring, so that probably amplifies the noise. Thanks again for the input.
Ted
Ted
