Sponsored by: Jekill and Hyde
New Engine Build
Old 05-29-2009, 12:27 AM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
Default New Engine Build
Well onto my next project or should I say money drop. Well talked to my local indie today and decided to go ahead and start the process of my engine build. Going with an axtell 107 kit. Im pretty stoked and hope to have the whole process of part and install done asap. Question is what are my options on cams, andrews tw-54 was recommended. Anyother options out there.
Going to keep my v h true duals so I know that I will be leaving alittle out there but just cant give those up. Also going to be staying with my PCIII.
So let me what you guys think. I will keep you updated on the progress.
Lynn,
Yes Im getting ready for my own little stuntin show!
Old 05-29-2009, 06:20 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Wiesco manufactures pistons to allow the boring of the OE cylinder to 3.935" that brings 88-98", and 96-107".
Assuming that the build is for the 2008 Touring bike in your signature, then I would suggest a Wood TW-7H. Has been the industrys top torque cam since the initial introduction of it in the mid-nineties.
Scott
Old 05-29-2009, 10:48 AM
SEDELUXE's Avatar
SEDELUXE
SEDELUXE is offline
the 54 is not the cam you want .... listen to scott the woods cam will really wakee up the build.
i have seen only one dyno sheet that has good numbers and it was from a so called builder tuner thief from mid west.
G
Old 05-29-2009, 06:07 PM
jackinthebox
G
thanks for the info
Old 05-29-2009, 09:41 PM
lkr0's Avatar
lkr0
lkr0 is offline
LMAO---a couple little things before you start your personal stunt show -- make sure you practice in a parking lot or like me on my cul de sac -- with that motor you will have know exactly (99% of the time) what the bike is going to do---my SG had a tendency to slide to the right then straighten up -- on the RG it has a tendency to go up in the air -- when I want to spin the rear tire I have to remember to hold the clutch just a little more and ease forward in the seat.
Good luck on the build -- I'm sure it's going to be a monster --
Lynn,
Old 05-29-2009, 10:52 PM
Bad Disposition's Avatar
Bad Disposition
Bad Disposition is offline
Default The New Engine build
Hey guys,
Is there a way he can get better numbers? I surpassed the 96-107 mark by just a little and I only have a 103...see the build and dyno sheet noted below. Will his V&H TD's cause him to loose that extra 1 hp and 5tq difference?
The Build:
2008 Ultra Classic fully loaded.
103 Ci
10:5:1 CP pistons
Superstock Heads
Woods Tw-5-6
Power Commander III
Crane Push Rods
Pro Series Rocker Arms
Mo-Flow Air system
Boned and polished 50mm throttle body
HD Oil Cooler
2-1 Thunder Headers.
Diamond cut Heads and Cyl.
Stock lower end.
=97.77 hp 112.70tq
I'm by no means a pro however, I would think for the extra $$ the 107 can make higher numbers. Forgive me if I'm mistaken.
Phil
Bad Disposition
Attached Thumbnails New Engine Build-img_02801.jpg   New Engine Build-dyno-copy.jpg
Old 05-30-2009, 04:11 AM
hpfatboy's Avatar
hpfatboy
hpfatboy is offline
You can NEVER go WRONG with a WOODS CAM!!! They are truly TORQUE MONSTERS!!!
Old 05-30-2009, 07:52 PM
schmeg's Avatar
schmeg
schmeg is offline
Oh yeh!
Old 05-31-2009, 11:54 PM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
Scott was saying that a 96in engine could be bored out to a 107in, and an 88 to a 98 in.
I really hard thinkin on having Mr. Scott do that itty bitty upgrade to my SG.
Man-oh-man.... a 107!!!
Old 06-01-2009, 07:11 PM
Dalton's Avatar
Dalton
Dalton is offline
The Woods 6 and 7 are good cams, and I cannot dispute they make great numbers, but my preference for that build would be the HQ575 if you are in the 10.3 to 10.5:1 range for compression. Again, a torque monster that is easy on the valve train and a little less pricey.
Quick Reply: New Engine Build
