Softail Deuce Exhaust
You can just put them on. The tuning will be pretty close. You will not run into any major issues. Only thing I see you potnetially running into would be some minor decel popping.
No need to have it retuned unless you encounter significant popping or other undesirable performance issues. You can have it retuned all over again but that's a lot of money. The simplest and least expensive way around decel popping is to not engine brake and pull the clutch in on decel. Another low cost method is to retard timing below certain throttle positions/RPMs. I used my SERT to do that on my Springer with Short Shot Staggereds. When I roll throttle back to idle on decel the timing goes to 45 degrees. Roll on and its back to normal timing with no hesitation or performance loss. Decel popping is gone.
What are your plans for the Hooker pipes? What kind of shape are they in? Thinking about selling them?
snowyhog
04-30-2007 02:14 PM
Tigger
06-27-2005 09:13 PM
