107 vs 103
having had both a 103 and two 107's (all three HQs complete builds) the 107 is most definently the way the go -- the difference in price is very marginal maybe $100. The power output especially on the torque side is night and day. It is amazing what 4 cc's will do.
I have rode hard on all three bikes, not one crank issue---I had the crank run out checked on all three bikes (this is a must) and all three were well within tolerance levels.
...ccs?
If'n ya want reliability, stay stock. If'n ya want to go fast, bigger is better.
No replacement for displacement.
This isn't always true though. Dual overhead cams, four-valves per cylinder, water cooling, high compression, tight tolerances and high revs go a long way.
reliabilty is there -- build it correctly the first time with components that compliment each other and it will last just like a stock motor or better
[QUOTE=lkr0;5036564]reliabilty is there -- build it correctly the first time with components that compliment each other and it will last just like a stock motor or better[/QUOT
Not an motor expert at all, but have to agree that if its buillt right with quality parts that it will be reliable.
I guess my point of the question is why go 103 over 107 since both dont require you to split the cases. Why not get the most bang for you buck?
